Hi All,
I'm looking for a dual cam setup for front and rear views. I currently have the multi-channel F70 (http://dashcamtalk.com/forum/threads/i1000-f70-x6-720p-dual-lens-dvr-dash-camera.21/) in my car, but it is too problematic. So I'm thinking of switching to two separate Mobius cams for front and back.
I have a few questions regarding this setup:
If any one has any better solutions for a dual cam setup, please share. I'm looking for a solution that is more reliable than the buggy F70 cam that I have now.
Thanks!
- In my current setup with the F70, it starts recording as soon as it receives power and stops recording and powers off soon after it loses power. Does a Mobius support this functionality?
- My car doesn't cut power to the cigarette lighter when ignition is off. To make it slightly quicker than unplugging the charger, I use a USB cable with a built in switch (http://www.dx.com/p/usb-to-micro-us...let-cellphone-black-120cm-280533#.Uzgm_HVDuY4). With a dual Mobius setup I envision adding a splitter at the other end to power both cams and so that I can turn them both off simultaneously. Can you guys see any problems with this setup?
- My cigarette lighter-to-USB charger has a 2A slot so I'm hoping I can hardwire both cams to the same slot. See any problems with this?
- Is running a long micro-USB cable from the front to the back okay? What is the typical setup for powering a Mobius cam at the rear?
- Both cams will only be receiving power when they are recording. In your experience, is this enough to keep the internal battery charged?
Thanks!
