BobDiaz
I re-did the test with a few extra things. The room temperature was 21C (70F), the camera was recording at the low bit rate, and painter's tape was placed on the rear heatsink. Where rear is defined as the heatsink farthest from the lens. Past tests showed that at the 15 minute mark, the temperature seems to level off so all readings were taken after 15 minutes.
Using a temperature probe I measured:
Case = 38C (100F)
Front Heat-sink = 48C (118F)
Back Heat-sink = 46C (115F) Has blue painter's tape on it
The Thermal Camera measured the following:
Case = 43C (109F)
Front Heat-sink = 24C (75F)
Back Heat-sink = 43C (109F) Has blue painter's tape on it
The camera is cooling off and the next test is with a 12 volt cooling fan running at 5 volts. The reason for the lower voltage is that a cooling fan makes less noise if you don't run it full power.
Case = 38C (100F)
Case = 43C (109F)
