- May 1, 2013
- Dublin
- Ireland
Whistler series flagship Whistler Zionist WP7
Same form factor as Rollei, HP F200 and many other dash cams with same body / casing.
It seems to be very popular design in Taiwan.
Whistler WP7 FullHD WDR wide dynamic the flagship night vision driving recorder
■ ultra-textured gold aluminum laser engraving design
■ the Ambarella A5 sports level chip program
■ 1920x1080P crisp and clear high-definition presented
■ 130-degree ultra-wide-angle view image sharpness
■ Up to 90 degrees heat resistance to high temperature ( Op temp -20 + 70 C )
■ WDR wide dynamic photosensitive balance
■ 3DNR noise reduction technology
■ F2.0 large aperture + the latest 7G crystal glass lens
■ 7-segment EV value The best results adjust the settings for brightness
■ H.264 high-definition MOV video file size compression
■ with seamless video does not leak second shift repository
■ G-Sensor lock file of the anti-override spontaneous the switch
■ flameout Pro stop moving Monitoring Photography protection
■ Built-in 470mAh rechargeable lithium battery explosion
■ label can be set to 8-bit alphanumeric personalized management
■ boot horizontal auxiliary line enhance license plate calibration function
■ Mute / WDR / capture / SOS lock file multiple shortcuts
■ Full machine with high stability dedicated Taiwan-made accessories
■ exclusive upper and lower the bracket holes institutions multipurpose
■ Full function remote port open (need to add optional Remote)
■ BSMI inspection Safety Certification: D3A199
Source: ( use Google translator )
http://newcar.u-car.com.tw/guidefeature ... leid=18001
http://item.taobao.com/item.htm?spm=a23 ... 3524468827
Thank you for reading my post.
