you should get around 3.5 hours give or take, the recycle setting will separate into blocks of whatever you set (5 minutes is typical) and you will always have the most recent 3.5 hours of video, if it needs more space it deletes the oldest 5 minute block of video (hope that's easy enough to understand)
Indeed! Thanks a bunch. I really feel like this camera is right near the top of my list.
Do you know what the difference is between the LS300W and the LS330W? Is the only difference that the 330 has the CAPABILITY of adding GPS? Or are there other improvements too?
Along the same lines, is the ONLY difference between the LS330W and the LS430W internal vs accessory GPS?
