GT450W WDR F1.6 Shadow-Tec by TioTech dash cam
For the installation into your car, are there any clips that are used to route the USB power cable from the visor to the a-pillar and eventually to a lighter socket?
There are no clips coming in the basic set, but you can buy them. However the best is just to run power cable under the liner via A pillar into the cigarette lighter or into the fuse box. Its fairly easy job.
Where can I buy these clips? I've looked for them everywhere, but with no luck. I have a Valentine One radar detector that I'm also using and dangling the cable straight down in the middle of my car.
Check on Ali, for sure you will find:
http://www.aliexpress.com/wholesale?Sea ... sPremium=y
Here I have youtube video gt450W vs DOD LS300W. Not sure if previously uploaded to "daylimotion" will be better or not.
ls300w very slight sharper picture quality.
Comparing raw files on PC screen I did not see any difference. Maybe you see it because of youtube compression + video editing soft when I was putting 2 files together ? But it not that important, overall video quality effect is the same day and night. It's just a form factor difference. Somebody dont mind slightly bigger design like ls300w, but for those looking for smaller dash cam, - gt450w is a good choice.
what, no way. The top is way clearer. You can see license plates definitely a couple frames earlier on the top one than the bottom. Nothing major, but I did read that the LS are just GT's that have ~12mb/s bitrate instead of 15+ like GT's do (I assume some different processing, could be firmware though).
The cheapest GT450w I can find right now is on aliexpress @ $99.70 A$2C
Seems all the GTs are about that price. There's a few LS for ~$70 but seem to be lower bitrate/quality video. Plus the 450 is tiny.
Ls300W, LS400, LS400W, - they all have 15Mbps, same as GT300W, GT350W, GT450W, GT550W, GT680w as well. Also G1W, G2W. They all record at 15Mbps.
Look-a-like range range like VF300W, LS650W, - they have 12Mbps
Givoe NEUTRAL LS300W has their own product code 244/2227
http://www.givoe.com/en/products/Su...LS300W-Best-Dashcam-supports-WDR-Full-HD.html
Foxoffer call it VF300W
They both advertise it as NEUTRAL.
So do not confuse with original LS300W, or original GT300W.
Edited: Not GT650W, >>> LS650W. ( it also has 12Mbps )
GT680W uses a bit rate of 15?
Another forum member said 12.5, check GT300w,ls300w price difference.
I am sure gt300w and ls300w average bit rate is 15Mbps
Yeah, but what about GT680W? Does it have a bit rate of 15 or 12 Mbps?
Its should be 15Mbps but I will confirm it in w680w thread after I receive it within a week.
Wait, what is the G1W/G2W? They sell for only ~$50, is that the same thing as the gt300,etc?
So basically, avoid anything that says 'neutral' or sold by 'givoe' (i see aliexpress, those cheap $72 ones were sold by 'givoe').
Lets address other dash camera models related questions in specific threads, not here. I see its getting too long and messy mixing too many other models into gt450w thread.
I will add GT680W info last time here in this thread, just to "close down" discussion on dash camera which is not from this thread.
GT680W has average bit-rate 12.5Mbps,
I have added raw video files in its thread along with bit-rate info:
http://dashcamtalk.com/forum/index.php?threads/shadow-gt680w.2311/page-2#post-25824
ADDED :
Strange, - according to this RAW video file I can see that GT680W has 15Mbps.
https://docs.google.com/uc?id=0BzimaSPeVAGpd0dJRjRJamlLNjQ&export=download
Don't knwo who to believe: Taobao, or other sources ?
Best is to wait until I receive my gt680w, then I can be sure 100%.
