[Xiaomi-Yi] Image De-Noise Methods
Hamdy
Egypt
Well i have searched for Scripts all over the web Found out there is a good Script for Increasing Sharpness which is t ia2 -adj tidx -1 500 -1 ..
1st Question : When i decrease the Number ( in upper Example its 500 ) to lower value does it makes the Image More Sharper !! ?
i've found that there is another method used in Noise Reduction Called Coring ..i dont get what this Method Does ? Beside that i found a Script and i didnt understand what to control
#disable sharpening. coring should contain only 256x10
#author: ?
t is2 -shp mode 0
t is2 -shp cor d:\coring.txt
Available modes:
0 - video
1 - fast still
2 - lowISO still
3 - highISO still
3rd question : Can i use Both Methods Together ? if No which one is better and why ?
Thanks in Advance
Take a few shots with sharpen, coring, then both together of the same item under very similar conditions, then pixel peep and check to see which looks best?
For denoise work post-processing images I find https://ni.neatvideo.com/ to be handy.
