egonvdv
- Aug 9, 2013
- A Dutchy in the South of France
- France
- TWO Thinkware's U10002CH (rear cams used as side cams)
I think you are talking about the other battery which is on the main board...?
I disconnected the gps & when I put the BV back together it was working.
only for some reason "audio on" audio off" just went into a loop by itself.
so took it apart again & re-assembled once more.
this fixed the loop... but gps once more not working (grrrr)
I'm still a bit reluctant to take out the battery, so I'll wait a bit
for a FW update...
btw; if you take out the battery, will it still show correct time in parking mode?
for a FW update...
