Review: HYUNDAI H92 Android Dashcam - Wi-Fi, GPS Navigation (Gearbest.com)
Sunny
Colorado
More than I can review. ;)
Thank you @GearBest for providing HYUNDAI H92 Android dashcam for review.
It's available at Gearbest here:
HYUNDAI H92 Android 4.4.2 1080P 170 Degree GPS Car DVR - MAP 1 BLUE AND BLACK
It's my first android based dashcam. Let's see how it performs.
Conclusion: will update after tests.
PROS:
CONS:
Description & Features:
Hyundai H92 android version: 4.4.2 | 4.5" 853x480 TFT touch screen | CPU: Quad-core Cortex-A7, 1.3GHz
Built-in 512MB RAM and 8GB flash memory
Built-in WiFi, support 802.11 b/g/n | FM transmitter (76 - 108MHz)
Chipset Name: MTK
Chipset: MTK8127
Product weight: 0.150 kg (Surprisingly, it's very light)
Product size (L x W x H): 12.50 x 7.50 x 3.80 cm / 4.92 x 2.95 x 1.50 inches
HYUNDAI H92 Unboxing video with menu settings:
Package contents:
  1. Hyundai H92 Android 4.4.2 Dashcam
  2. Suction cup with screw mount
  3. Mini USB car charger
  4. Mini USB PC cable
  5. Manual
  6. Visiting cards
  7. Warranty/registration card?
Product images:
To show relative size, Hyundai H92 side-by-side with NanoQ (mini 0903) and Vantrue R2.
H92 is huge but it's made for multiple purposes, Dashcam, GPS navigation, FM transmitter, Android tablet...
Front has reset hole below the lens housing.
Most of the ports are on left edge of the camera: mini USB, microSD, headphone out.
Not a fan of that huge chrome housing, probably will cover it with black electrical tape.
Combined with the size, blue front and chrome housing, it's not made to be discrete.
BTW, it's very light looking at the size.
Microphone hole on the bottom:
Nothing on the right edge:
Power button and tripod mount screw jack on top:
H92 Android home screen:
H92 Car DVR (dashcam mode) screen: It starts in DVR mode and starts recording even when connecting to a computer.
More coming soon...
Hyundai H92 Android Dashcam Folders and Files:
Root folder has one folder named DVR.
Videos: I:\DVR\video
Photos: I:\DVR\pic\f201-60-40-front
There are few other folders that I'm not sure about yet.
File size for a 3 minute 1920x1080p video file is around 278 mb.
Each video file also has a small xml file.
Pictures are 4000x2256p resolution and each file is around 775 KB in size.
Each picture also has a small xml file.
Hyundai H92 Dashcam VBR: Overall bit rate is 12.7 Mbps with video @ 12.6 mbps and audio @ 48 kbps (128 kbps nominal).
Format : MPEG-4
File size : 272 MiB
Duration : 3mn 0s
Overall bit rate : 12.7 Mbps
Video Bit rate : 12.6 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 30.273 fps
Minimum frame rate : 28.409 fps
Maximum frame rate : 32.397 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Bits/(Pixel*Frame) : 0.201
Stream size : 271 MiB (100%)
Audio Bit rate : 48.0 Kbps
Nominal bit rate : 128 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 16.0 KHz / 8 000 Hz
Frame rate : 7.813 fps (1024 spf)
Compression mode : Lossy
Stream size : 1.03 MiB (0%)
Test video screenshot:
Test PHOTO mode at the same time as above:
Reserved...
Daytime videos:
Note: Startup is pretty long, around 40 seconds so you either have to wait before driving or hope nothing happens within that time. ;)
Same video from NanoQ (mini 0903) has around 38 seconds of video by the time H92 starts recording.
Here's NanoQ video of the same time: NanoQ Comparison Video.
Daytime video screenshots
: Video quality is pretty good. It's similar to Novatek based cameras. Not too sharp and colors look little washed but details are there.
Audio quality is very good.
Here are few screenshots, some in residential areas, some at stop, some against the Sun and some in highway @ 70 mph.
Haven't figured out yet on the GPS part... it seems that it doesn't have GPS info on the videos.
Next to mini 0826 in the vehicle:
From inside...
From outside:
That thing is bigger than my A6000 CSC apart from a slight thickness difference. So APS-C in a dashcam may not be such a dream after all! Lol
Video looks good. Thanks for your sharing!;)
Night video: from highway to residential area.
Night video screenshots:
Wow, that is very decent. The exit sign is very readale.
Yes, I'm pretty impressed with night quality.
Here are few more night videos:
Decent night video. What is it 1.7 or 2.0 AP?
Navigation:
Not sure how to use this yet.
It has four navigation apps:
KaiLiDe
Baidu
GaoDe
ShanlingDSA
However, clicking on any of them starts iGO logo so I guess all are using iGO behind the scene.
There is no map loaded so I'll have to find map that works with one of these apps.
Hi, everyone. Can you help me with this device. By mistake i flashed a wrong rom and now my device is bricked. Can anybody backup the stock rom and send me by link. Thanks in advance.
I'm not sure how to backup the ROM.
It's Android so it would be possible.
Maybe manufacturer has it somewhere to download.
Yes, indeed. There are lot of applications, rom manager and so on. But who is the manufacturer? Is they have a site. Someone maybe can backup stock rom.
