CamBurn
- Oct 2, 2015
- United Kingdom
- Mini 0806 3rd gen firmware 150512
I don't always hear it turning off but I have heard it shutting down as if I had cut the power etc
But it seems to be a random shutdown.
It also happens when parked! I checked it was working when left the car but only blue light on when I returned to car!
Had quick search and found this post. Is there any other things that can fxi this problem or is it a dead loss?
https://dashcamtalk.com/forum/threads/on-off-issue.20604/#post-285922
Pins looks fine, mount seems tight, when working recording ok etc.
Is this the time to dismantle and get my soldering iron out?
Appreciate any ideas that don't include using a hammer on it!
PS. Just checked and waiting for cam to turn off.
It started flashing the red and green lights erratically for about 30 seconds, then they went back to flashing normally for a few minutes.
Then red and green stopped flashing and stayed on for about 1 minute. Red and green both went out at same time leaving only blue light lit.
Then cam shut down with the usual sound. I don't have the screen on when in use!
Last 2 recorded files play 100% ok.
2nd from last file is 650mb's
Last file is 146mb's!
