Exactly was firmware V1.01.
Was this Firmware 1.0 vs 1.2? Or was it 1.01 vs 1.2?
The jump from 1.0 to 1.01 was massive. If this is 1.01 to 1.2 it's even bigger!
I used a Hama 64GB microSD card. No issues.Is a 32 GB maximum sdcard really necessary? I only have 64 GB here.
No sorry that's not true and I've just registered to report that 1080 60p is now broken under low light and I hope it will be solved as soon as possible. Solution: use 30p.@viofo Just to let you know that your last firmware update 1.2 was a great success. The IQ quality was 100% improved. The traffic lights now show the true colors and license plates can be read very clear at much longer distances. I do not think that the A119S needs anymore improvement. The A119S surpasses even more expensive DVR's in quality and overall expectations. You have great engineers on your staff.
Is it possible to upload a clip and tell which setting you use.No sorry that's not true and I've just registered to report that 1080 60p is now broken under low light and I hope it will be solved as soon as possible. Solution: use 30p.
Oh that's interesting! I'm using default settings after reset. I will upload something later.
Thank you it's a honour!Forgot to to welcome you to the forum.
Welcome to forum.
This is probably an issue with your camera or your camera settings and not an issue with 1.2. I am on 1.2 and am not experiencing the issues you describe while filming in 1080/60.No sorry that's not true and I've just registered to report that 1080 60p is now broken under low light and I hope it will be solved as soon as possible. Solution: use 30p.
It's immediately visible when going from standby screen and start the recording manually: the light colours and the noise get very bad.
v4 firmware camera settings | A119S | 2 | ||
How can modify firmware for Large font. ? | A119S | 0 | ||
V | A119S Unable to Dowload Firmware | A119S | 2 | |
T | VIOFO a119s FIRMWARE | A119S | 72 | |
Viofo A119S Official Beta firmware | A119S | 57 |
