- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
No it needs to be wired to power, accessories and earth just like a power magic pro
As a camera they're as limited as other Korean dual channel models in regard to image quality and low bitrate results, they do however have a very good parking mode, good power control and a good app, for parking mode they would certainly be one of the best options at the moment
I know my previous Lukas cameras had this built-in, too. but that still required the wiring to ground / ignition / battery just like a battery discharge prevention device.
does the F770 do all that with regular plug-in 12V power supply or does it require the same 3-wire setup?
NiceMine should be here Monday, I will be using the plug in at first so we will see. I am also going to order two little G1W-Hs (they are so little and cheap why not), so when I get those I will get it all wired in.
So Joikiin, what's happening with your forthcoming dual channel camera?
Will it be focused on video quality, or parking mode quality?
I'm lucky that we rarely park in direct sunlight for long periods.chasing video quality as a primary concern, parking mode is not the priority but we will see what can be done
