What is the lestest firmware of Blackview DAB201
The firmware that I have installed is v2385. It is stable.
Most video file problems are due to SD cards. Check your SD card.
My firmware is lastest version,
And replaced SD card.
But,I will re-flash firmware and resetting for test again.
Thank you for support.
I use kingston 64GB class 10,and sandisk 32GB class 10
Thank you.
SanDisk Ultra? If so, not a good card to use. Very troublesome. Kingston should be OK, but have not used one in a Dome camera before.
I use kingston 64GB/10,no problem.
Sometime,I swap to sandisk ultra 32GB/10,no problem.
I think,I can fix issue.
(Test for 1 week)
Problem:When first connect the GPS,DAB201 auto change the year and month to 2017-01.
Important,It can't loop delete future folder.
My dashcam DAB201 error create year fail.
It create folder 161215000 and 170115000,record time not continue
In the menu,My setting "Time Zone Set"= +7 On
I fix the problem:Set the "Time Zone Set"=Off
I think fixed it,Thank you for support.
on 4pda.ru forum have message to the firmware version ZX-AMF-G-3099Y and link to download for version dub 205. But it has successfully put on the dub 201
Only yesterday a man to flash. testing. menu is not changed.
I can't download the firmware version ZX-AMF-G-3099Y.
Error 404
I'm updated and test new firmware for 1 week.
Test it OK.
Does 3099Y fix anything or let you disable the speed from the display? I've been using the v2382 custom bitrate firmware for the past year without issues.
I'm tested custom bitrate firmware,It stop record
Memory card low speed warning and stop record.
Please explain what you mean. I am not sure what you meant.
I think he means that he tested the firmware and got the memory card low speed warning and it stopped recording. His SD card speed is probably too slow for the High Bitrate firmware.
D D201 9
96902 D201 42
Pinni3 D201 0
