Converting cigarette lighter plug to usb
dvct
Greece
Thinking of chopping off the cigarette lighter end and converting it to usb
I know I can just buy a long cable but I'd in DIY mode right now, so has any of you done this would you consider it “safe”?
which adapter do you have?
this is the power cable the camera came with:
and after conversion to USB I'm going to be plugging it to this:
Model Blitzwolf BW-C1
Input DC 12-24V Max
Output DC 4x2.4A/5V Max
Would be simpler just to buy a new cable.
But if you wanna DIY, just cut after the 12>5v converter and use one of these
https://www.adafruit.com/product/1387
It will look much neater than soldering it to a chopped plug.
Thanks!
Yeah, I guess a could just buy a cable, but I already routed the existing one in my car and I thought it might be quicker to just cut the car adapter plug and switch it with a USB connector like the one you linked to.
Hi, sorry to hijack the thread but I have a related question.
I have accidentally bent and broke the mini USB connector. Can I buy a standard micro usb to usb cable and use that to power the dash cam? I have an adapter in the 12v port that has usb ports on it.
also how long is the cable that comes with the a118c2?
Y A118 (B40) 2
S.D.M.F A118 (B40) 16
