Hi Viofo, would it be possible to change the behavior of the camera so that if no choice is made between "Mass storage" and "PC camera" for 10 seconds, then the camera simply records as if it was plugged in on a power supply ?
You could also make a choice "Normal operation" but it needs to timeout to this choice
The reason is that I power my camera using a USB port outlet from my radio, but it cannot work because the camera won't simply work in this. If you do what I said above, it will start working after 10 seconds which is fine.
This modification could also be done on A119 and A119S and will improve the cameras
Thanks !
