RAW photos from Z26L / firmware 1.5.6 coming out purple
DSun
Hi all,
I recently bought a Xiaomi Yi and was trying to develop RAW photos, however, the photos come out with a really strong purple cast in Lightroom (see attached
PCKQq
). I activated RAW image file creation using:
#Reduce noise reduction as much as possible
t ia2 -adj tidx -1 -1 -1
#Create RAW files
t app test debug_dump 14
I converted the RAW files to DNG with the following settings:
;config by nutsey
31850496, 0, 4608, 3456, 7, 9216, 16, 4, XIAOMI-YI
...and then drag-and-drop the resultant .DNG file into a batch file with exiftool in the same folder. The batch file contents are;
@echo off
setlocal enableextensions enabledelayedexpansion
SET /A COUNT=1
if [%1]==[] goto :eof
:loop
exiftool -WhiteLevel=1024 -BlackLevel=50 %1 -overwrite_original
ECHO !COUNT! file(s) processed.
SET /A COUNT+=1
shift
if not [%1]==[] goto loop
Any ideas on what I can do to fix the purple cast?
Thank you
EDIT: attached image
