Easy to make CPL filter for GT300w, LS300w, LS330w and more
Dutchdashcam
Apeldoorn
Netherlands
Mini 0801/0805 DOD LS360w DOD LS460W Vico Marcus series
This is an easy way to make your own quick removable CPL filter from a piece of PVC drain pipe.
The B+W filter fits exactly (in the Dutch dimensions of available pipes with rubber seal, outside pipe- dimension is 3.6 cm
The rubber seal in the pipe ensures that it fits on the cam. You even can turn it around due the rubber ring.
Anyway, it works fine on my cams.
Great job.
I have done month ago something similar to Panorama II using 5ltr water bottle cap.
