veenugget
Background
I've hardwired the B1W into the fusebox of my car (red to fuse, black to ground, yellow not connected) and for the first couple days it's been working with no problems. The only thing I have changed recently is the firmware - updated to Parking Mode firmware found here - 20180614s. The SD card I am using is the SanDisk Ultra A1 64gb. I'm pretty sure this is the newer SanDisk microSD card without the faults.
The problem
Recently the B1W would, during a drive, enter into what I believe to be Parking mode (because the green LED light is solid and does not flash) for a while and then turns off. After a while later, the B1W would turn back on with voice prompts (SD card detected, Recording Start etc). A couple minutes later it'll go back into Parking mode and repeat. It's not continuous. Sometimes it will happen multiple times, sometimes it won't happen at all. I don't know how to reproduce the symptoms.
Has this happened to anyone before and does anyone know a fix?
My immediate thoughts were:
The problem
- Fusebox
- Voltage protector set on too high (but this shouldn't happen during a drive right?)
- Firmware
