erkme73
- Jun 30, 2013
- a119v3 x 4
For the first time since having both the Android head unit and 0806, today I attempted to play back recorded segments from the camera by putting the µSD card into the head unit. No dice. Android (AOSP) does not recognize the exfat format. That is something I knew, but since my Samsung Note 4 has Touchwiz, it has no issues with exfat.
Sadly, this means unless I format the cards in NTFS or FAT32, it doesn't look like I'll have that plug-n-play luxury I'd envisioned.
For grins, I had the head unit format the camera card - at which Android recognized the correct capacity and directory structure. I then put that card in the 0806, and weird things started to happen.
1) The camera didn't automatically start recording at power up. It just sat there in standby mode. It eventually powered off (timed out).
2) I manually hit the record button, and the camera appeared to be working just find. I let it record several 3-minute segments, and then pulled the power. At that point, instead of shutting down, some never-seen-before warning popped up saying something like "Card not optimal, format now?" I selected no, and then it just sat there, not recording, but not powering down (though eventually it shut down due to power off timer).
4) The files that were created on the android-formatted µSD showed properly on the head unit, but when I tried to play them, my default player (MX Player) locked up.
Just a heads up to anyone intending on using an AOSP-based (non-Touchwiz) Android device to play the exfat formatted cards - it won't work.
