yesIs it still true with the latest firmware?
CPU/DSP not support ((I wonder why 60p could not also be reduced from 2304x1296?
That "crap" in gopro 3+ /4 too )) More FPS -> less inital resolution / details in video (but in gopro inital resolutions better than in xiaomi)Well that is crappy
In fact, it's more limited by RAM than other else. According to SONY the sensor can do itCPU/DSP not support ((
In factIn fact,....
yes yes yes it сan, but does not want to ( on xiaomi , on sj5000+ , on blackview hero ,etc... even gopro 3+ with some more power cpu/dsp and 512 ram)ccording to the A7LS briefSheet it can handle it(Raw up to 16MPixel at 30fps,it may do 8MPixel (4K) at 60fps)
Manufacturer so stupid that saved 1-2% of money by using 256 ram module ))) He can use for examle 512mb ram and add 2048×1088 60, and sell camera like 2k 60fps !!! But he so stupid ))))but sure there is not enough RAM to do more than the Yi actually capable of.
OMG i have H264 L5.0 . Its not possible )DSP may too according to H264 4.2
I dont see any proof for it in any known cameras. Sony sensor can use lower modes but not higher.the sony sensor can do more than recommended/default supported resolution
Ok gopro 3+ has no "much optimization" too ? )) It has maximum optimizations in firmware i think , and have better dsp, and still dont have 2k 60 ))I don't think there is very much optimisation there almost the base Ambarella provided firm stuff.
I didn't say it can do higher just said it can do different than standard ones .I dont see any proof for it in any known cameras. Sony sensor can use lower modes but not higher.
maybe , maybe not... the gopro3+ may had a A7 right ? (which is different than A7LS)Ok gopro 3+ has no "much optimization" too ? )) It has maximum optimizations in firmware i think , and have better dsp, and still dont have 2k 60 ))
It because DSP limitation, not sensor , or ram .
> 16MP RAW at 30fps or 8MP (4k2K) at 60Fps but in RAW mode.Image Sensor Interface
° 480 MPixels/s processing
Protune its just more bitrate + some hands settingsAs the differences between capacity with PROTUNE and not PROTUNE videos on GOPro,
So where is it used ??? )) No one camera on a7 have more than 4k 15 ))))> 16MP RAW at 30fps or 8MP (4k2K) at 60Fps but in RAW mode.
more bitrate less processing , flat colour.Protune its just more bitrate + some hands settings
I dont think that flat color its less processing )) Its just different color settings (or like scene mode in xiaomi).more bitrate less processing , flat colour.
DSP is hardware processing , and not need much resources.it's reallocation of ressources.
not so ugly but i dont like gopro colors too )) ( i have gopro 4 black )a not processed PROTUNE is an ugly not "usable" video.
I dont understand . You know what better for me ? )))but "better" for you is not "better" for an other. that's it.
In xiaomi i use script with random color settings and dont see any difference in performance .more you calculate adjustment in colour more you need analyzing.
ARM ? DSP do all work with image processing . ARM control it , and all sistems.AIM to control everything
The opposite. for example, You can like warm color adjustment and I can prefer cold adjustment.I dont understand . You now what better for me ? )))
because you are processing color in all way, there is analysis in all the profiles. if you take this brute color as it come out from the sensor, it may can save some ressources (no more colors, highlights and shadows adjustment) . maybe not siginficant but sometime even few more ressources can make the difference.In xiaomi i use script with random color settings and dont see any difference in performance .
YiMax Pro 1080p 24fps 50mbps? | Yi Action Camera | 0 | ||
When recording 1080p@60 the somund gets out of sync, anyone else? | Yi Action Camera | 4 | ||
B | Setting the bitrate 1080p to 60-90mbps ? | Yi Action Camera | 4 | |
D | Highest bitrate for 1080p 24fps | Yi Action Camera | 1 | |
H | 1080p 60fps on iOS(iPhone 5) | Yi Action Camera | 0 |
