RavenManiac
- Jun 18, 2015
- Williamsburg, Virginia
- Viofo A129 Duo, mini 0806 (RIP)
I've decided to add a second 0806 to the rear of my Honda CR-V. To power it I intend to take Nigel's suggestion and run a 15' Micro USB cable from the dash cam to a USB adapter at my fusebox. I
just went online to buy a 15' Monoprice cable with ferrite and the reviews are terrible. I really don't want to go through the time and trouble of installing a 15' cable only to have to replace it in a year or two. Has anyone had any issues with Monoprice cables? Is there another brand you would recommend?
Also, the cable will need to go from the headliner to a rear window mounted 0806 on the lift gate, which means the cable will be repeatedly bent whenever the lift gate is opened. Unfortunately, I don't see any way around this so I need a cable with good durability that will have to resist some flexing and compression.
