Hi Dashcam folks!
I have just bought this on ebay. http://www.ebay.co.uk/itm/380532169887? ... 1497.l2649
Does the job g=fine on 2gb card and 4gb sdhc.
however, just bought 2 x 16gb sdhc sandisk cards. thes i have checked and seem fully serviceable. However, the cams only record very short clips and then stop (between 30s and 2 min) (I have tried all the settings and this still happens). The clips are actually then not recorded. If you stop the recording manually the clip is saved on the card.
The cam should work for up to 32 gb sdhc so am a bit bamboozled. I have tried formatting both in the PC and the cam and no difference.
Note I bought 2 cams and 2 cards. The issue is the same with both cams and cards etc.
Any advice jolly welcome.
thanks.
thanks.
