2019 Mustang fuse tap
JdNorthCoast19
Anyone have a picture or can recommend which fuses to use for ACC and Batt for a Mustang?
Post a picture of the fuse diagram. It's usually on the back of the box cover.
Look at the fuse diagram in your manual. Try to find non critical systems to hook up to.
I use my power seats (Front or Driver doesn't matter) for Battery (Red).....Check your manual to see if Power seats are tied into any other system. If not these are a good choice.
For ACC (Yellow) I used my heated seats....If you have heated seats, check manual and make sure nothing else runs off fuse....I found this to be a good choice.
Pretty much AVOID any safety systems / electronics. Try to piggyback off a non essential system
2016 Mustang
2/36
Goes without saying, please post a picture from your manual describing the fuses. So we can help recommend good ones to use in the event the ones selected are improper.
OP states he has a 2019, aside from a bit a mid-year refresh, I don't know what would be different on the panel.
Here is from the manual:
However, the real way to test is to use either a voltage meter or the incandescent tester kit that comes with the hardware cable kit (at least it does from BBMC).
A
View attachment 45486View attachment 45487
#2 for ACC might be ok. #23 or #26 might be alternatives (#23 especially) without tapping into modules that control systems..But I doubt #2 will cause issue.
#24 might be a better fit. Not sure what all ties to Auxillary Body Module. But then again, if you aren't experiencing any issues, then should be ok,
A
Mine’s working as advertised... haven’t heard from the OP so perhaps he/she figured it out.
Z A129 / 129 Duo 2
RavenManiac A129 / 129 Duo 104
RavenManiac A129 / 129 Duo 39
