Hull aero drag is important, the shape of the hull is designed to produce aero lift using ground effect flight and to avoid the crew adding much aero drag.Hull drag? What's hull drag
Tech vid played. Sometimes YouTube sucks...
I hope that was bio-methanol, suitable for this threadI like those top fuel drag boats,,,,,
Does Twitter work in USA?Tech vid played. Sometimes YouTube sucks...
Is Denmark supporting the mega dam?Actually it is a major problem in many places of Denmark, a big storm at high tide even with the dikes we have build since the last catastrophe, well it could happen again, and the dikes are mainly along the west of Jutland.
Can't use concrete for something that size, unless it is zero CO2 concrete That is not possible because cement is limestone with the CO2 removed!not even sure where we should get all the materials from, the amount of concrete needed will be staggering.
In 2016, world cement production generated around 2.2 billion tonnes of CO2 - equivalent to 8% of the global total.
“To put it mildly, gas is over,” Dr Werner Hoyer said at a press conference on the EIB’s annual results.
No, we don't use concrete, I think they mainly use suction buckets, sucked into the sea bed, far less CO2 emissions, and the steel can be fully recycled. Obviously you use wind power for smelting the steel so no need for carbon emissions.Without concrete foundations there can be no wind turbines,
The GE Halide X is 825 tonnes just for the bit on top of the tower!These contraption can be pretty big too, i think 100 tonnes are pretty standard.
It is actually a little taller above than below, though the mass must be the other way around:Remember like iceberg only a little is above water.
I wouldnt beleive that study one bit.Someone just released a study here in regard to CO2, seem like a tenderloin put out as much CO2 making as a drive in a average car from Denmark to Paris.
2022 Climate Change | Off Topic | 1 | ||
2021 >>> 2022... | Off Topic | 0 | ||
Streets of Bakhchisarai, Crimea 2021(Улочки Бахчисарая, Крым 2021) Street Guardian SGGCX2PRO. | Off Topic | 3 |
