2022 Chevrolet Bolt EUV Premier Hardwire Installation
yabadabadoo
Just wondering if anybody has hardwired a dashcam to their 2022 Chevy Bolt EUV Premier yet? I have got an A119 V3 from VIOFO that I would like to install, but I am not sure the cigarette lighter (Power Outlet) fuse is labelled in the Instrument Panel Fuse Box schematic...
Also, I am interested in hearing about your experience of hardwiring the cam to a constant-power fuse and its affect on the battery.
Hi and welcome to the forum!
There are lots of threads around here about hardwiring your dashcam. Generally, hardwiring means that you are not using the cigarette lighter/utility port. Rather, people connect directly to a constant 12v supply - either the car’s 12v battery or an additional parking battery. It sounds like you are looking for the ability to record while the car is parked. Is this correct?
I don’t have any experience with a chevy bolt, but your overall goal is to find a 12v power source, usually from the fusebox. Some fuses are likely to be always on, while others will turn on and off with the key. With an image of the fusebox from the manual, there is enough help around here to guide your efforts.
