2Ch Blacksys CH-100B (1080p+720p) Sony Exmor, WiFi, GPS / Glonass, Supercaps, Up to 128Gb, BDP
niko
Retailer
Dublin
Ireland
NB!
Do NOT comment in this thread !
All comments and questions must be posted in the main Blacksys CH-100B thread
> CLICK HERE <
• CPU Texas Instruments
• Wifi 802.11 b/g/n (2.4GHz)
• 2.4M pixels, Sony CMOS Sensor / Lens: 1/3"
• Low Voltage Cut-off System
• High Temperature Cut-off System
• Resolution front camera 1920x1080 (Full HD) 30fps
• Resolution rear camera 1280x720 (HD) 30fps• Wide angle front 135°
• Wide angle rear 130°
• GPS SiRF 5 Dual Band (GPS + Glonass)
• G-sensor, 3-axle shock detection for event recording• Video format H.264 (AVI) / Codec profile: HIP (High Profile)
• Bit-rate front camera 6Mbps, 30fps
• Bit-rate rear camera 4Mbps, 30fps
• Rear camera is supplied with a 6 meter cable
• Fragments per 3 or 5 minutes
• Loudspeaker embedded, volume adjustable
• Microphone embedded, on/off
• Voice Guide, voice assistant in English, volume adjustable
• Parking Mode, automatically activated, on/off, time setting adjustable
• Motion Detection in Parking Mode, records already 10 seconds before a movement or shock!
• Event Recording, in case of sudden movements (impact, emergency break, deviation) the video clip will be
automatically saved in a separate file and will not be automatically deleted when the memory gets full
• Emergency Button, just 1 push on this button and the 10 seconds before and the 20 seconds after the incident
will be saved in a separate file and will not be automatically deleted when the memory gets full
• GPS functions; route, speed, via Google Maps
• Time and date stamp
• Temperature Sensor
• Current DC 12V~24V
• Power use 340mA (13.4V) (Wifi off)
• Operational temperature -20°C ~ +70°C
• Storage temperature -30°C ~ +80°C
• Dimensions front camera 5.8 x 10 x 3.4 cm, 78 gr
• Dimensions rear camera 5 x 2.6 x 3.1 cm, 25 gr
• Memory external, microSD memory card (16GB~128GB)
• Software developed by BlackSys to view footage on PC (Android and iOS)
• 5 cable holders
newcop Multi-Channel Dash Cams 6
