2x DOD LS460W vs BlackVue DR750LW
Ox10ef
Poland
Hello
I was thinking about buying dashcam.
I want to have best video quality at day & night. (the ability to read the license plate of the car in different conditions).
Camera also needs to be reliable.
I google'ed some information and I am thinking about
BlackVue DR750LW
OR
2x DOD LS460W (1 for front, 1 for rear).
One sites has some comparision table about quality of various cameras (dual / high-end / mid / afforable etc).
From this site, I came into conclusion that DOD LS460W records better at night (it is probably the best 1080p camera for recording at night).
I watched some movies at youtube and it is legit.
But, the selling point for BlackVue DR750LW is that it's dual camera, so:
- it would be more convienent:
a) 1 usb charging cable
b) 1 SD card -> less hassle with downloading
c) you can show rear display at LCD panel (something like parking sensor - I don't have one in car)
So right now I can't make final decision. Any thoughts?
How difficult would be to setup "2x DOD LS460W" and configure it, so I can show rear video at some LCD panel?
2000rpm
Many, including JooVuu, Mobius, Street Guardian.
I wouldn't rush to buy a DOD (sometimes sold as Nextbase in the UK). I've had a few DOD/Nextbase cams and I they only lasted for a few thousand miles; maybe OK as a good-performing cam for light-duty use but they don't seem suited to heavy-duty use.
They are impressive straight from the box (they are also expensive so they should be impressive) but DOD seem to have skimped on build quality in some areas; often warm weather or long run times causing focus shift (cheap lens housing?) and premature battery failure (cheap battery? / poorly designed charging circuit?) seem to be regularly encountered problems in a number of DOD models.
2000rpm
The cams with best video quality are often newer models with bugs still to be resolved.
You'll also usually find there's a trade-off between ability to read number plates and the camera's field of view. Narrow-angle cams are best for capturing number plates but may only see between the 11-o-clock and 1-o-clock position whereas a wide angle cam will see between 10-o-clock and 2-o-clock. Beware manufacturers boasting about wide field of view - many of them twist the truth!
The cams with best reliability are often 'second rate' models which have been around a few years and where the manufacturer has fixed the bugs.
Module 79L
Portugal
AT11DA, SG9665XS, G1W-H
(...) maybe OK as a good-performing cam for light-duty use but they don't seem suited to heavy-duty use.
Then maybe we should start asking first what use the person will give to the camera(s) and then recommend some models, not the other way around. ;)
