AndyN
Hi all
I have a 522gw with the rear camera, it has been hard wired for about 18 months but I have now changed cars and am just using the socket charger. The battery is dead holds no charge, after 4 or so hours charging inside you get 2 to 3 seconds then off. It also means when my engine auto stops and re starts and the voltage drops the blooming camera goes off and sometimes does not come back on.
I have seen threads talking about instructions on how to change and where to get replacement batteries from is it possible I could get this information.
I hope they are pretty cheap as 18 months is a bit pants if i have to replace them at cost each time.
PL 353040H 3.7V 320mAh 1.18Wh this seems to be the model according to another post but any idea where you can get them from, Amazon has similar but not quite the same.
