ChrisFlynn
Hi al,l
I got a 522W as my first ever dashcam this weekend. The bloke in Halfords said two things I'm not sure I fully understand:- that I need to format occasionally as it won't automatically overwrite old recordings, and to not use the Protect button as it will lose data. Having read a bit of the manual and others posts here, I think I understand where he's coming from, but I just wanted to check I've understood correctly...
Is that right? Or have I mis-understood? Thanks in advance?
- Because I have front and rear cams and the standard 32GB, the capacity is 2hours.
- Occasionally, the device will automatically protect files (1min), based on the GPS/accelerometer. These protected files don't get recorded over.
- The risk is that if 90mins of protected files build up, then I'm really only reusing 30mins of coverage. So if I drive home after an accident and haven't manually protected my accident files, I could lose them! So that's why after an accident, I should either manually protect relevant files, or unplug the device.
- The reason it's recommended to format the card every few weeks is to delete protected files.
- The "Protect" button doesn't automatically protect the current files, but rather minus 10s to plus 20s. So the worst case scenario is that I press the Protect button to save a useless chunk, and then drive home (with limited capacity due to automatically protected files) overwriting my accident files.
- This means the "Protect" button is about as useful as a chocolate teapot, and most customers (but not NextBase) think it ought to protect the previous and current files, not this different 30s block. So not worth using, other than to take a picture of something that's about to happen.
