5ghz wifi not available
ahbib
Latest firmware dr900s 2 channel.
The cam only shows 2.4ghz wifi even when selecting 5ghz option in firmware settings.
Weird thing is that when selecting 5ghz option in firmware it goes to 2.4ghz but it is using 40mhz band meaning 2 channels on the 2.4ghz frequency.
Ex. select 5ghz in firmware options, cam stays in 2.4ghz mode but uses channel bonding to make it use channels 1 and 3.
I just want to use 5ghz for less interference in my wifi saturated area. but the dr900s on the latest firmware is not going into 5ghz mode at all it is in either single channel 2.4ghz mode or channel bonding 2.4ghz mode.
Any help would be appreciated.
Thank You.
evad
Retailer
Zielona Góra
Poland
BlackVue DR900S (primary) & few others...
Do you use BV Cloud and camera is connected to the 2.4GHz WiFi router perhaps?
Wysłane z mojego ONEPLUS A5000 przy użyciu Tapatalka
Ralph2
Edmonton AB
BlackVue 650GW in 2011 Highlander
I think most WiFi cameras do not have 5G capabilities wired into them. An extra cost that is not yet integrated into most homeowners systems.
