DreamDriver
My 622GW freez at startup from time to time, the touch screen don't work and it is impossibel to turn it of.
I will try to set "Parking mode" to "Off" from now on, because it often starts before I turn on the car and maybe it could cause a conflict in recording when the car starts.
So maybe setting Parking mode to off, can be a short term solution, I will try to remember to post here how it goes ;o)
NEXTBASE it would be so nice, if this problem was adressed by you, in the next FW version, this have been an issue for some time and a similar problems, if not the same, are in 522GW, SO please do some professionel handling of this problem.
622GW
Rear Window Cam
SD card: Scandisk Extreme Pro 128GB SDXC UHS-1 U3
FW Ver. 6.2
Dual Files Off
All Stamps On
G-Sensor Off
Parking mode On - Will be set Off in future
It works perfectly, IF you end the "Secure recording" started by the "Parking mode" function, BEFORE you start the car or don't use the "Parking mode" function at all.
The problem is, that the FW does not make sure, that the recording initated by the "Parking Mode" are finalized and writen correctly to the SD card, before the normal "Power on / start car" sekvens are excecuted.
The result are corrupted communication to the SD card and a dead lock situation in the writing process
So it seems that NextBase has some room for improvements in some future FW update.
Some one asked what sd card I use: Scandisk Extreme Pro 128GB SDXC UHS-1 U3 and in the troubel shoot fase it was formated almost daily.
622GW
Rear Window Cam
FW Ver. 6.2
Dual Files Off
All Stamps On
G-Sensor Off
UPDATE 14-04-2021It works perfectly, IF you end the "Secure recording" started by the "Parking mode" function, BEFORE you start the car or don't use the "Parking mode" function at all.
