Shane2801
@NextBase Support
The Good - Records clear video
The Bad - Everything else.
I purchased a 256gb card (High end, met all specs needed).Stupid me fell for the "You must only use a Nextbase Card" routine so I purchased a Nextbase 32gb card to see if this was infact the problem. No it wasn't!! There's $60 wasted. While I'm on the subject why would Nextbase release a camera that records in 4K and only offer a 32 & 128gb card?
The camera will not connect to my PC. When I connect, the drive only pops up for a second then dissappears. This is not a PC related issue I can assure you. So I had to go out and buy a card reader. I cant see how removing and re-inserting a micro SD card does alot for the card or camera I must say.
Dont get me started on the battery.... When I unplug from the car I get one bar which lasts for about 2 minutes. Is this normal??? I doubt it.
After researching onthe internet about this brand of camera I notice there are countless threads like mine and it seems Nextbase just comeback with the same rheatoric. Reset the cam etc...
My biggest problem is that I cant get rid of this brand as I have installed the hardwire kit and also purchased the rear camera. So unless I want to throw away close to $800 spent its not an option unfortunately. I would really be impressed if Nextbase could reply to this thread and actually acknowledge these problems and give me a fix.
