622GW polarising filter replacement possible?
SELdn
London
First-time poster here.
Really clumsily on my part, I closed the glove box door on my unit, causing the polarising filter to crack.
Rotating the filter moves the cracks, so the lens glass behind the filter is fine.
I can still get good footage, except when facing directly towards the sun and at night - so I would like to fix it.
Is there a way to remove the current filter and put on a replacement?
@NextBase Support maybe you can advise?
Thanks.
Hello,
The 622GW has a screw-on filter, which can be removed if broken. Just screw the cracked filter off until it's released from the camera.
A replacement filter can be purchased from our spare parts website, and then screwed onto the 622GW. Here's the link:
Kind regards,
Millie
Nextbase Technical Support
