Julian23
- Nov 16, 2016
- Germany
- Several brands :)
After testing the 70mai Omni 4K (X800) extensively, I'm onto the next 70mai dashcam.
Big thanks to 70mai for the opportunity to test their new flagship again!
Other than the Omni 4K, this is a triple-channel setup. The T800 is their latest high-end dashcam and their first to offer dual 4K channels: both the front and rear cameras record at 3840×2160, powered by Sony STARVIS 2 IMX678 sensors. That’s already a major leap compared to most rear cams, which still stick to 1080p or 2K.
The interior camera adds full infrared night vision using four 940 nm IR LEDs, making it ideal for ride-share drivers or anyone needing reliable cabin footage at night. All three channels support HDR (High Dynamic Range), and the main unit uses a super-capacitor instead of a lithium battery, making it far more heat-resistant. Perfect for parking mode and summer use.
On the connectivity side, the T800 includes Wi-Fi 6 for fast downloads and a smooth live view in the app. The GPS module is included in the housing, and you get full ADAS support (lane departure warning, forward collision, pedestrian alert) as well as optional 4G cloud support for live streaming, GPS tracking, and cloud alerts. The T800 does support the UP04 or UP05 4G module for cloud features. The camera can be remotely monitored, settings can be changed and more.
There are two versions of the T800 available: the HDR Set and the Premium Set. This review focuses on the Premium Set, which includes the RC41 rear cam with the same IMX678 sensor as the front. The HDR Set, on the other hand, uses a 1080p-only RC24 (IMX662) but allows 4K60 recording in single-channel mode. In triple-channel operation (Premium Set), frame rates are 4K30 front, 4K30 rear, and 1080p30 interior.
Specs (Premium Set):
Unboxing:
The box itself
The manual and SD card are in a cardboard box.
The cameras and both cables.
Both cameras
- Front Camera: 3840×2160 (4K) @30fps, Sony STARVIS 2 IMX678, F1.7 aperture, 146° FOV
- Rear Camera: 3840×2160 (4K) @30fps, Sony STARVIS 2 IMX678, 146° FOV
- Cabin Camera: 1920×1080 (1080p) @30fps, 4× 940 nm IR LEDs, 147° FOV, 45° tilt up/down
- HDR: Enabled on all channels
- Display: 3.0" IPS LCD (non-touch), with physical buttons
- Storage: microSD up to 512 GB (U3 required)
- Connectivity: Built-in GPS, Wi-Fi 6, optional 4G cloud via UP04/UP05
- ADAS: (LDWS, FCWS, PCWS),
- Parking mode: Time-Lapse, Motion Detection, Collision Detection
Unboxing:
The box itself
Both cameras
