70mai A900 Dual 4K Dashcam with 4G Cloud - Unboxing & Testing
Yeah i would think, once the speed have been determined by what ever frequency, after that is is just a matter of stamping it onto the footage.
So for the rear to behave different sound strange
But i suppose there could be a technical reason.
Testing the DDpai Z60 master, i found the footage from the 3 cameras wildly out of sync, but if something like that could be a reason to brand / update a remote camera different i can not say.
I have no clue as to what could be done in camera to account for such things.
Screen dump from my editing tool, after i synced the 3 tracks up and snipped off the front end of the Z 60 Master 1 minute files.
I've found the same with DDPAI Z90 Master and Z50 Pro, it's still out of sync by a second or two. Funny because in their update changelogs, they keep mentioning they are fixing time sync issues. For like the last couple of years lol.
Anyways, yeah don't know - all the data I've pulled from the A900 points to 1Hz intervals. Happy to be proven wrong though.
Interesting, are you able to provide the testing methodology for this finding, as I'm sure others may wish to confirm on their own devices (whether that be customers or other curious bystanders)?
Yes. I checked it properly now and I also need to correct my original 5Hz statement.
I initially assumed around 5Hz because I was recording with 50Hz Anti-Flicker, which means the A900 records at 25fps. Based on the update rate I saw, I assumed it would scale to around 5Hz at 30fps / 60Hz.
I've just tested it at 60Hz as well and it stays at around 4Hz. So the actual embedded GPS telemetry rate in the front MP4 is around 4Hz.
I analyzed the GPS data directly inside the original front MP4 files. GPSData00001.txt was not used.
Two 60 second files gave me:
File 1:
240 GPS changes
Average interval: 249.67ms
~4.005Hz
File 2:
239 GPS changes
Average interval: 249.87ms
~4.002Hz
I also checked the individual GPS updates themselves. Each update contains a new GPS value compared with the previous one.
The GPS information inside the MP4 can also be extracted with ExifTool.
I used my own local analysis tool for the detailed interval calculation.
So correction from my side: approximately 4Hz embedded GPS telemetry, not 5Hz.
I dont think so even with the strictest testing circumstances, but i will assume it could show a difference between a 1Hz system and a 5Hz system.
I am confused there is a difference in the update speed in between the front and rear cameras, wouldn't that mean there is 2 GPS systems in there then ?
I checked the rear file more closely as well.
There is actually no GPS telemetry stored inside the rear MP4 at all.
The rear video only has the speed/GPS information burned into the video overlay. The embedded GPS data is only present in the front MP4.
So no, there are not two GPS systems.
The front MP4 contains around 4Hz embedded GPS telemetry. The rear MP4 has no GPS data track to compare against.
Not sure about the updating speed for the rear camera either. That's why some insight into the testing methodology would be beneficial for power users here on DCT, at the very least.
Yes, and that was one of the things confusing me.
After checking the files, the rear MP4 does not contain embedded GPS telemetry at all.
Only the front MP4 contains the GPS data.
The speed information you see on the rear recording is just part of the in video overlay, so there is no rear GPS data rate to measure.
Yes, I would have found it very strange if the rear camera had its own board along with GPS module. Entirely as anticipated, the data is collected all in the main dashcam unit and provided as a video overlay for the rear channel .
I am also curious about that statement. I presume there is only one GPS module in the camera, so all video streams would have the same GPS update rate and geolocation stamp. I'd think they should always match, or be within a second or two (due to latency), across all cameras.
The best resolution to this is to ask 70Mai what their GPS 'update rate' is.
Yes, the GPS data is only embedded into the front MP4 file. I still don't know why the refresh rate of the overlay is lower for the rear channel. Maybe to useless processing power?
From my testing the update rate is 4Hz based on the embedded GPS telemetry in the front MP4.
That still does not necessarily tell us the hardware update rate of the GPS receiver itself. 70mai would have to confirm it.
EDIT: Not sure if I am doing it correctly, but I pulled the GPSData00001.txt file from my A900, and it says it is being updated at 1Hz per second. However, this mismatches with what the speed refresh rate on the dashcam itself appears to be showing. The mystery thickens,
Your result with GPSData00001.txt is correct. I get the same thing.
The separate TXT file is only around 1Hz.
But that is not the same GPS data that is embedded inside the front MP4.
When I analyze the MP4 itself, I get around 240 actual GPS changes during a 60 second recording, with an average interval of almost exactly 250ms.
So:
GPSData00001.txt: ~1Hz
Front MP4 embedded GPS telemetry: ~4Hz
Rear MP4: no embedded GPS telemetry
I also checked the actual GPS values and they really change between the updates.
You can extract the embedded GPS information from the MP4 with ExifTool.
So:
I am extracting it now and it says there is no defined GPS data for the video file, minor tag GPSdatetime not defined.
Also looked through all the fields under the file and not there. Have tried on a few video files now, both downloaded off the APP and copied off the microSD memory card. And have run it through online EXIF tools, but all of them say there is no GPS metadata to extract.
So:
Perhaps you have found a bug? I think the .txt file logs events, and the displayed frequency update rate is hard-coded, while the remaining location data is dynamic.
But I can also see that the 4 Hz may refer to the G-sensor data, depending on where it appears in the string and what 70Mai decided to embed. If your cam's G-sensor is set to low sensitivity, you could switch it to high, record a video, and then check whether the 4 Hz has increased. That is just a guess on my part.
Of course, 70Mai could tell us for sure, but I don't know how open they will be with information.
One other thing to keep in mind is that some dashcam manufacturers store GPS data in a proprietary format or structure. I know of several dashcam manufacturers that do this. In that case, the average EXIF tool usually won't pull that GPS information out.
After doing some extended testing with other files pulled using ExifTool. These were a Viofo dashcam , DDPAI dashcam and 70mai dashcam - I was able to pull GPS data from the Viofo file. But not DDPAI or 70mai A900 files.
This leads me to believe that they are either a few options:
1. The GPS data is kept only in a separate log file
2. The GPS data is kept in a proprietary container
3. The GPS data isn't embedded at all in the video file
I would be hesitant to take this information as gospel that the A900 is sampling the GPS data at 4Hz, when there appears to be no proof that this is the case.
If 70Mai answers contrary, I'm happy to take that as official confirmation though.
I was able to pull the Data from 70mai, Viofo, Vantrue, Vueroid with my tool. The GPS data is definitely in the video file.
Below you can see some specs.
The most interesting part is to the right. The GPS Hz. The front channel of the A900 clearly stands out, while the rear channel has no GPS data.
Since you wanted proof, see below.
Here you can see the actual GPS data that is included in the file: (position data is partly redacted)
Some more...
A mean interval of around 240-250ms will result in a 4Hz reading.
I can take any front camera file of my A900 and it will have a similar result.
Feel free to send me a PM with one of your clips and I'll run it in my tool and give you the results. 😉
You were able to get the Vueroid GPS data? I am surprised by that. What tool are you using? The reason I am surprised is that the Vueroid GPS is containerized and not easy to get too, this is due to the Vueroid file structure and other reasons.
DDPAI has told me they keep their GPS in a proprietary track/container, and it is not easily available. I am awaiting an answer from 70Mai.
The Viofo GPS is easily available.
Yes, I am able to get the GPS data from all the brands I mentioned, including Vueroid. The tool is selfmade.
Well there's no doubt that the update frequency is more than 1Hz, but we will have to see what these companies say in some official capacity as it's all conjecture at this stage otherwise.
It will definitely be interesting to hear what 70mai has to say about this.
But with the data I have gathered, I'm pretty confident that these results are correct. Otherwise, the data wouldn't be in the files.
Here is the reply from 70Mai; there was a bit more about the reasons why, but the gist is this, and I quote:
Our actual refresh rate is 4 Hz (as shown in the video), but the rate for saving to a separate file and uploading to the cloud is 1 Hz.
It's impressive that their base update rate is 4 Hz; this shows 70Mai has put thought into GPS reliability and accuracy.
Thanks for the update.
Just what I expected based on my testing.
