70mai Dashcam Pro Plus+ A500S Rear Cam Set review
Jeremy Wong
Kuala Lumpur
Malaysia
Viofo A119, Viofo A119S, Xiaomi Mijia, 360 J511C, etc
Author's Note: The original review is found at jwtech, please head to the site to show us your support as well. Click here to view all my product reviews!
Special thanks to 70mai for sending over their latest 70mai Dashcam Pro Plus+ A500S Rear Cam Set for review.
70mai Dashcam Pro Plus+ A500S technical specs:
• Processor: Novatek NT96580
• Sensor: Sony IMX335
• Lens: 2-layer glass, 4-layer plastic, 140° wide angle, F1.8 aperture
• Resolution: 2592×1944 30fps, 2560×1920 30fps, 1920×1440 30fps
• 3D Dynamic Noise Reduction & Wide Dynamic Range
• 2” IPS Screen 480×360
• Supports up to 128GB microSD card
• Built-in 500mAh Lithium Polymer
• Built-in Wi-Fi 802.11 b/g/n 2.4GHz
• Built-in GPS
• Parking mode
• ADAS
RC06 rear camera Technical specs:
• Processor: Fullhan FH8536H
• Sensor: Galaxycore GC2053
• Resolution: 1920×1080 25fps
• Lens: 2-layer glass, 2-layer plastic, 130° wide angle, F2.0 aperture
The box
Open box
Contents
• 70mai Dashcam Pro Plus+ A500S
• Tape mount
• 70mai rear camera RC06
• Dual USB car charger
• 90° angled micro USB cable 3.5m
• 90° angled rear cam cable 5.5m
• Pry tool
• Electrostatic sticker x4
• Spare mounting tape
• 70mai Dashcam Pro Plus+ user manual
• 70mai rear camera RC06 user manual
Tape mount
Micro USB cable
Rear cam cable
Pry tool
Spare mounting tape
70mai Dashcam Pro Plus+ A500S user manual
70mai hardwire kit
In order to use the 70mai parking surveillance mode, you’ll need to install the 70mai hardwire kit. You can’t enable parking surveillance mode without this hardwire kit installed now.
Contents
• 70mai hardwire kit
• User manual
70mai hardwire kit
User manual
Initial firmware out of the box
Test setup
Using a 128GB Samsung Evo Plus microSD for the recordings.
Videos
70mai Dashcam Pro Plus+ A500S recorded in H.265 2592×1944 30fps with an overall bitrate of 24.8 Mb/s.
70mai rear camera RC06 recorded in H.265 1920×1080 25fps with an overall bitrate of 10.3 Mb/s.
Final thoughts
This 70mai A500 series is an upgraded 70mai Dashcam Pro. Now the newer 70mai Dashcam Pro Plus+ A500S has dual dashcam functionality with the RC06 rear cam.
The 70mai Dashcam Pro Plus+ A500S now uses the Novatek NT96580 processor instead of the Huawei HiSilicon Hi3556 V200 processor in the 70mai Dashcam Pro Plus A500. I am liking the change to Novatek by 70mai. But I do hope in the future there will be a 70mai dashcam which will be using super-capacitors instead of lithium batteries.
The ADAS of the 70mai Dashcam Pro Plus+ A500S, I can say that is about 80+% accurate like my Thinkware U1000’s ADAS. 70mai's parking mode will starts recording when there's a trigger of the G-sensor.
Is there any pre-buffering of parking mode vids? If not what's the delay time between sensing and recording start?
After viewing some of the vids it seems like the lens lets it down a little but given the price you can't have everything. I don't think it would do well with capturing US plates, especially at night with there being too much motion blur. Doesn't look as good as the A800 did, maybe they're not as familiar with the NT processor yet as they could be. Sad they were forced to change processors.
Good review as usual 👍
70mai doesn't have buffered parking mode. It's starts recording when the g-sensor triggers during parking mode.
Sent from my SM-G988B using Tapatalk
Parking mode will start recording after 5 seconds of detected impact making it not so useful. Also, it will take some good effort to get it to trigger.
Thanks for the detailed review, interested in this for sure.
Can you tell me if you can switch to the rear camera on the screen? I'm hoping to use this as a rudimentary reversing camera for a car that I don't drive very often.
You can switch between front camera or rear camera on the screen by pressing the left button
Hi Jeremy,
How did you connect the dash cam to the 70mai App, I select Add device from the list select 70mai Dash Cam Pro Plus+, connect to the dash cam hotspot the app shows "Connected to 70mai_A500S_XXX" but when I press Connect button it takes me back to WiFi settings, I thought it could be my old phone info below so I tried my friends iPhone 7 iOS 14.4 same result, 70mai support is useless no answer to emails.
LG phone Android v7.1.2
70mai app v1.8.1
Pro Plus+ firmware 0.0.9Aww
I had similar problems with all my cam apps and my LG Phoenix3 Android 7.0 😉 I found that once I get the app connected on the connection screen, using the "back" button (little triangle on bottom left) takes me back to the app home screen then everything works from there.
