turnerzzzz
Hi, use this version:
Set the "English" language in the settings. If you set another language (rus, jap, korea), then the registrar will work, will not be silent. Use this information if you need a "silent mode".109ww_for_CN_ver_ENG.zip
drive.google.com
This firmware turns the Chinese version into an international one. It is based on the new international firmware 1.0.9ww. After the firmware, use only the international application 70mai. In the app, in the settings, you will see the version number 9.9.9. This is normal. I did this on purpose so that the application would not find a new version of the international firmware and install it on the Chinese version. But I think the 1.0.9ww firmware is the latest.
Good luck to you. Write me if everything works out for you.
P.S. For everyone. This firmware is only for 1S (D06) for the Chinese version of the device. Not compatible for D01.
1.Format the memory card with the DVR (insert the card into the recorder - turn it on - format it (press the button 3 times) - recording will start - turn off the recorder - pull out the memory card)
2.Unzip the firmware file FW_DR0008.bin from the archive
3. Copy the FW_DR0008 file.bin to the root of the microSD memory card.
4. Insert the memory card into the DVR.
Connect the device to an external power source. (not from USB, use a native memory or compatible with a current of at least 1.5 A)
5. The device will turn on and start flashing blue (the firmware process has started)
6. After a successful firmware update, the device will say something (it may not say, this is normal) and turn off (the blue LED will go out)
Turn on the device by pressing the button 1 time.
Thanks Lisabon! This works like a charm.
International apps on iphone now works.
English voice command now works.
App notice sound now in english.
Thanks a lot,
You are a genius!
