Hello all-
Recently purchased an A119V2 from OCD Tronic. Noticed a weird chirping/pulsing sound while recording audio. Currently on firmware V3.3 but certain it was there on 2.6 as well.
I found a few other threads with some workarounds ranging from turning on the startup sounds to taking apart the camera to move the speaker....?
https://dashcamtalk.com/forum/threads/a119-gps-buzz-each-second.25690/
https://dashcamtalk.com/forum/threads/pulsing-audio-issue-with-gps-mount.29518
I can confirm that having startup sounds turned on OR navigating a menu with "button beeps" on OR pressing the "lock" button will make the chirping noise go away, until the camera reboots. Here are two videos I recorded that show the sound before and after the camera makes a "beep" via button press.
Before Button Press (Camera has not beeped before recording):
After Button Press (Camera has beeped at least once before recording):
There has to be a better workaround than turning on startup sounds, because I'm not a huge fan of the loud startup laser sound effect. Hopefully this is something that can be fixed via firmware.
