RTBoston
I've read all the suggestions.
1. Assuming this is V1 given when I purchased it.
2. Same issue using GPS puck or side of device for power cord.
3. Same issue using original lighter power plug.
4. Same issue using different cable and USB power in the house.
5. Same issue using different cable and laptop.
6. Same issue with two different SD cards.
7. Same issue if no card inserted.
8. Had one problem back in early 2018, but SpyTec replaced it under warranty (seems they got out of dash cam business since). Ran flawlessly since.
9. Issue started about a month ago and would happen every 10th car start. Till now, when it is constant.
10. Guessing this thing is toast unless someone has a card suggestion or things there is something relatively easy to fix hardware related.
Any last minute thoughts before I hit up Amazon for a new version?
Thanks in advance-
Thanks in advance-
