A119 Mini USB Port Question
SR14626
Florida
Viofo A119 Mini - Blackvue 900S
Diagram below shows two USB input slots. One is for hooking up the power for the camera and it’s on top of the GPS Module, but the second one on the right side, Can that also be used for power or is that just for data download to my iPhone or computer? Dashcam is in route, so I can’t play with it as of yet.
Received my Viofo A119 Mini and successfully set it up, using the vehicle front USB port, with only the included USB cable from Viafo without the cigarette lighter adapter. Tested and all is well. May not work with other vehicles, but for my 2023 Honda HRV with a 2.5A input, it did work.
I will now have to hide some of the wire, but I know it won’t be a professional job.
The only snag is that 2.5v port is also the only port to connect a phone or memory stick to the infotainment unit.
It's a shame Honda restricted the other ports to 1a that is underpowered for dashcams.
True for some, but I have a wireless pad on my 23 Honda HRV EXL, so that helps with eliminating the phone Connection.
As far as I can see, the HRV uses the same 'option connector' as the latest Jazz/Fit. I've wired my dashcam into the option connector port of my 2022 Jazz hybrid. They are tricky to obtain as they only seem to be on Amazon.jp
I also run Android Auto wirelessly but I do have a music memory stick in the 2.5a port.
