borik
- Sep 26, 2016
- 2 A119's, A119 Pro
so, what firmware version do you have now?Only tried one firmware at a time. Yes, card is formatted as FAT32.
the firmware update takes ~1 minute. did you see any REC button flashing?
try to do it step by step, and write down what you do and how, and what you see on a camera screen. good luck with the firmware upgrade!Hey ,There ,GIRLGUYs,,,I found this thread and am having same Brain storm problem ,,i am a Tech by trade and feel like my brain hurts. I have A119 i believe V2 with V3.6 trying to upgrade to 4. I haven't yet tried all the suggestions mentioned yet, as i just found them ...Thks.
like @5Cowbells said - download the .bin file from the top of the Viofo support page, that file is 4.04 MB (4,246,272 bytes).Hey ,Guys I successfully upgraded the software ,, but weird thing is it says Ver. A119_180730_V3.91 ,,, maybe they revised it for A119,,,,, All i did was delete all video files ,on my Lexar 64gb sd card and went to Viofo site downloaded the FWDA119.bin 3.88mb file and added it the the SD card ,, and safely eject it out of usb on PC and into usb power block plugged in My short usb with Dashcam and it started its led dance and shazam thk u mam,, i wonder if they made changes to the file ,, cause its not V.4 ??? Lifes a bitch and them u die.
how much time did the upgrade process take? in seconds, please.Okay verdict is neither the V.4 works or Beta V4 works ..it goes thru the flash but near the end it makes a small click and is dead until i flash the bin back to V3.91 . Whats up??
once I had to repeat the firmware upgrade process 3 or 4 times in a row until it was finally successful. "normal" upgrade takes about 60 seconds. and it might take longer, I think.I don't know the seconds ,, but i think it was at the end of the flash .
It is updated.Download the version at the top left of the Viofo A119 Firmware Support page "A119 V4.0 Firmware". There was a problem earlier that the files at the bottom were V3.91 that may not have been fixed.
A119 V2 gps mount pins bent, how to bend back to work again? | A119 | 11 | ||
V | Does A119 V2 have a rechargeable RTC battery? | A119 | 15 | |
A119 type with GPS/Traffic has horrible 2 Meter HAM radio noise! | A119 | 2 | ||
N | Is my A119 v2 on the way out? | A119 | 4 | |
N | A119 unable to power on from GPS module | A119 | 6 |
