Hi!
I have A119V2 as a front and main dashcam. I've got another A119V2 cam and I want to use it as a rear dashcam. Both of them will be connected to the cigarette socket.
Therefore I need a cigarette socket conector with 3 USB connections, in case I'd like to charge also my phone during the rides.
Moreover, the cable (almost 4M) of the dashcam is not long enough from the back of my car to the front. I need almost 8M.
Then:
1. Do you think there will be a problem to connect these 2/3 devices during the rides? There will be enough voltage for all of them?
2. I think the connector of A119V2 is mini USB type B. Do you think a long cable of 8M/10M will be OK? I know there are some who says it's a bit problamtic, but I also heard many who charge other devices with these lengths. So I'm not sure... Do you have another idea who can I use it as rear cam without using another long cable?
3. I guess mini USB type A won't work, right? only type B?
Thnkas for your help!
Then:
