Can you add link so I can buy?Loose gps to Camera will corrupt files.
A possible fix is some cloth tape (gaffe tape) between the GPS mount and camera.
Or there is a product kicking around that is a slim foam that goes between the camera and gps.
@LateralNW@Bengoof
Have a read about it on this forum. Here's the link.
https://dashcamtalk.com/forum/threa...-viofo-a119s-dashcam.28903/page-3#post-411773
I'll see if I can find a link.
@LateralNW
do you mean this video:...
Thanx for the link.Yes.
Here is a link to Amazon.
https://www.amazon.com/gp/B072DS2DW9
I just used tape is cheaper.
Have you tried playing the damaged files in the dash cam?
It has the ability to fix corrupted files.
Yhe Is really hot in hereYes if the camera is rattling a little on the mount it can momentarily loose connection and this can confuse camera and result in corrupted files.
Also it will be bad for the audio recording if the camera rattle in the mount.
If you take camera on / off all the time to spare it from the blistering heat in Israel then things ( camera - mount and EVA foam pads will of course wear down quicker )
Good its not your memory card on the way out
If not done so previously try connecting power to the input port on the side of the camera body rather than the GPS mount. GPS will still receive power.Hi i have A119 V20 powers with gps mount, V3.6
I've connected the power to the input port on the side of the camera body >much batter.If not done so previously try connecting power to the input port on the side of the camera body rather than the GPS mount. GPS will still receive power.
If the last video is always corrupt, it is possible that your capacitors are faulty. A way to test is to watch the red REC button light (LED) while you power down the camera. It should remain lit for about 5-7 seconds. If it turns off sooner, your capacitors may be faulty.I've connected the power to the input port on the side of the camera body >much batter.
Now only the last video of every trip wont play.
If i watched that particular video on the camera itself next time i playing it on the pc> worked just fine.
strange,
Any thoughts?
U mean turn off the camera by switch off car/take the USB cable off or there's a way to turn off the camera by pressing some button?capacitors
A119 V2 gps mount pins bent, how to bend back to work again? | A119 | 11 | ||
V | Does A119 V2 have a rechargeable RTC battery? | A119 | 15 | |
A119 type with GPS/Traffic has horrible 2 Meter HAM radio noise! | A119 | 2 | ||
N | Is my A119 v2 on the way out? | A119 | 4 | |
B | A119- camera wont lunch automatically when engine start. | A119 | 9 |
