jei13
Greetings all. Would like your opinion on the following.
I've been using the A119 V3 for a couple of days now, normally at 1440p30 resolution. Today, I wanted to see how the 1080p 60fps video looked. But while playing back the 1080p60 file on my different computers (I7-7500U laptop & I7-8700 desktop), to me it didn't look as smooth as your typical 60fps video. It actually looked more like 30fps to me, even though Windows file properties correctly showed 60fps frame rate. This was on the original 1.00 firmware. So I updated to 1.02 and tested 1080p60 again, but the file still did not look 60fps smooth to me upon playback.
FYI, I used my usual card, a 128GB Samsung Evo Select (sequential read speed 89 MB/s & write speed 84 MB/s according to CrystaDiskMark). I also tested with a 128GB Sandisk Ultra Plus that was lying around. Same result (60fps not looking smooth).
I recorded two 1-minute clips shot one after the other in bright sunny weather, one in 1080p60 resolution and the other 1080p30. Both high bitrate mode. While checking the file properties in Windows, what's strange is that while the file size of the 1080p30 clip is 166 MB, the 1080p60 clip in comparison is only 181 MB. I was expecting the 60fps file to be a lot larger, since in theory it would have recorded twice the amount of frames as the 30fps clip. Again, Windows file properties does correctly show the 1080p60 file to have a 60fps frame rate.
Here is each file directly uploaded to Youtube along with raw file download links:
A119 V3 at 1080p60 High Bitrate Mode (1.02 firmware)
1080p60 File Properties -- Length: 1 Minute; Resolution: 1920 x 1080; File Size: 181 MB; Total Bitrate: 24,681 kbps; Frame Rate: 60.00 frames/second; (playback looks more like 30fps to me)
Raw File Download Link
A119 V3 at 1080p30 High Bitrate Mode (1.02 firmware)
1080p30 File Properties -- Length: 1 Minute; Resolution: 1920 x 1080; File Size: 166 MB; Total Bitrate: 22,622 kbps; Frame Rate: 30.00 frames/second
Any ideas about this? Is this normal for A119 V3 1080p60? Could it be my microSD card? Wondering if any other A119 V3 owners have also tested at this resolution and frame rate and can comment on the smoothness, file size, etc.
