Thanks, I have a vico power plus want to use. I had my hopes up.
Just to be clear.... I can use it as a power supply only correct. What voltage does the Viofo cut off at?
not really as they do also offer an automated parking mode in the latest firmware betas so the camera can change to parking mode based on lack of movement, it's not as definitive as the 3 wire method but still works ok for most usersCut and dry question, if I use the Vico or a Power Magic Pro the A129 Duo will not go into parking mode, but will just run as if the car is still running or the key is still on?
Thank You, I know I sounded like I don't know what it does (poor grammar) as I have used it and a Power Magic Pro with other cams, but I'm still confused.
I just hate letting the Vico go to waste. I ponder if the USB 2 wire pin-outs can be adapter via the Vico?
