Hilts
- Mar 24, 2014
- Wales
- United Kingdom
- A129 Pro Duo, A129, Duo & Mobius Maxi 4K (with capacitor)
I purchased my A129 from VIOFO Ltd, via Amazon UK, on 24th September 2018. It has functioned very well for a while and it used to obtain a GPS signal less than 20-30 seconds after of being turned on.
Recently, however, the GPS receiver module appears to have stopped working. On playback of the videos the Speed and Location information are now missing, having been present when I first started using this.
I get a message on screen telling me ‘No GPS’ whilst the GPS function is ‘On’ in the Settings Menu - I've checked the GPS function is 'On' (both using the VIOFO App and on the A129 directly). The 'No GPS' message remains regardless of how the unit has been on for, i.e., it never obtains a GPS signal.
The A129 is correctly attached to the GPS module:
I have tried the following:
1. Resetting the unit - both within the A129 Menu and also using the 'Reset' on the side.
2. Reloading the Firmware (V1.3).
3. Connecting the mini USB power supply directly to the GPS module and also via the USB port on the side. The unit powers up normally with both.
4. Using a mains 1A USB (phone charger) supply to the GPS module and also via the USB port on the side. Again the unit powers up normally with both.
Any ideas what else I could try?
Has anyone else experienced a similar problem?
I'm suspecting the GPS module has failed - but thought I'd check with the gurus on here first!
