borik
- Sep 26, 2016
- 2 A119's, A119 Pro
We are developing an IR version which will support to record interior.
I don't think the main unit must be updated. Maybe the firmware will be different.
enjoy,
Mtz
The IR version can be also used current A129 front camera.So besides how long this will actually take to become available, I would also like to ask if the IR-equipped interior camera would be a simple drop-in replacement for an already existing A129 rear camera? In other words, could I use this not yet available IR-equipped interior camera with an A129 front camera/main unit that is available today, or will some part of the main unit also need to upgraded/replaced (other than just upgrading the firmware)?
what is that front to rear cable, really?Some users already use the rear camera like this, they require a 30cm rear cable, is it OK?
is it just a charge+data cable with some extra insulation and miniUSB connectors at the ends?
if I want to put that rear camera on my door facing outside, I would need a cable like 1.5 meters (not measured yet), where could I get that cable?
thanks!it's 10 pin USB, not a standard mini cable
that's understandable. I wonder if @viofo would make 2-3 cables of different length.that's the type of connector, I wouldn't use just any cable though, if the cable is poor quality you will have issues
I said "1.5" meters just for example. could be 2 meters. I want to be sure I can find the cable I need.different length cables is no issue, not sure how viable a 1.5m cable is, we do them in various lengths for ours but I don't know that we would find much call for a 1.5m version
that's understandable. thanks, jokiin!we do them in a bunch of different configurations, straight, left, right connectors, and various lengths, 55cm, 3m, 3.5m, 6m, 6.5m depending on the application, you really do need something that's made for this purpose though, if it's not intended as a camera connecting cable it's unlikely to work without interference or connectivity issues, regular USB cables aren't good enough for this
I had responded directly to Viofo because it doesn't really matter what any of us thinks -- but rather what the manufacturer foresees based upon its own specific knowledge of the product and its roadmap for its future.
Same answer as mine. I put the think word just to be polite.The IR version can be also used current A129 front camera.
Maybe 50cm is safer? The big question is if the user will want to put the cable ”in the air” between main camera and slave or he wants to put it under the roof and then down to the slave camera.Some users already use the rear camera like this, they require a 30cm rear cable, is it OK?
I know is hard to believe but some of us have more knowledge or informations than you expect from a user. And this is adding the value and power of a good forum.
enjoy,
Mtz
I know you are from USA, but wouldn't it have been more appropriate to say thanks to both Mtz and Viofo for their efforts to help you?In advance of a response from Viofo, the actual manufacturer who happens to be available in this forum, your answer was at best only a presumption, a guess. Should you had been incorrect, would you then offer to reimburse anyone who bought an A129 today and then could not add an IR camera to it later?
After a direct response from Viofo however, your response could have been considered useful and appreciated distribution and dissemination of more reliable information.
And I happened to guess too that it would make most sense to have an IR camera be plug and play -- for various reasons. But I asked for a more certain response.
he's part of their internal beta test group, his reply wasn't a guessIn advance of a response from Viofo, the actual manufacturer who happens to be available in this forum, your answer was at best only a presumption, a guess. Should you had been incorrect, would you then offer to reimburse anyone who bought an A129 today and then could not add an IR camera to it later?
R | Viofo A129 Duo not recording if rear camera is connected | A129 / 129 Duo | 1 | |
A129 Rear Camera Or Cable Fault? | A129 / 129 Duo | 14 | ||
A129 Duo Rear Camera Issues | A129 / 129 Duo | 9 | ||
F | A129 Duo - Can you mount the rear camera on the windshield?? | A129 / 129 Duo | 14 | |
M | A129 duo rear camera mount replacement | A129 / 129 Duo | 2 |
