Thanks for the education. Yes, unfortunately, my DASHOTO hardwire kit came with fuse taps with 16awg wire and 15 amp fuses. I found this good resource for auto/car electronics. It says that the largest recommended fuse for 16awg wire is 7.5 amps.
So if the insulation on that cable rubbed through against a piece of metal then the fuse would allow 15 amps x 14 volts = 210 watts to flow through the cable before the fuse blows, about the same as an electric car kettle - it can produce more than enough heat to start a fire. Then remember that car furnishings are not self extinguishing like home furnishings, once a fire has started the car will fully burn out.Thanks for the education. Yes, unfortunately, my DASHOTO hardwire kit came with fuse taps with 16awg wire and 15 amp fuses. I found this good resource for auto/car electronics. It says that the largest recommended fuse for 16awg wire is 7.5 amps.
Electrical car fires tend to result from a short circuit where the insulation gets broken down until it is extremely thin, then you get a very poor connection between your cable and corroded metal covered in melted plastic, the amps that gets conducted then gradually rises generating more and more heat in the cable until either flaming plastic insulation starts to drip off the cable, or the fuse blows.And here is the response from DASHOTO
Hello everyone,
I'm very sorry if that's a pretty dumb for the most of you guys, but I'm unsure.
I ordered a Viofo A129 including a hardwire kit, a fuse tap and a fuse but they forgott to deliver the fuse and the fuse tap does not fit my car anyway, because it (Honda Civic 2017) needs a Low Profile Fuse.
I'm now not sure what kind of fuse I should take for the A129, the electrical store nearby only has 10 amps, but I assume that 5 amps or even 2 amps would be better right?
Cheers
Regal
"I used 15 AMP fuse for both "
As mentioned, most of the kits come with fuse taps with 16awg wire. The max recommended amps for this gauge wire is 10, so by placing a 15 amp fuse you are letting the wire act as the fuse, which is not the best idea. See links above.
Wire Gauge | Recommended Maximum Fuse Size |
00 awg | 400 amps |
0 awg | 325 amps |
1 awg | 250 amps |
2 awg | 200 amps |
4 awg | 125 amps |
6 awg | 80 amps |
8 awg | 50 amps |
10 awg | 30 amps |
12 awg | 20 amps |
14 awg | 15 amps |
16 awg | 7.5 amps |
Actually, some kits came with 7.5 amp fuses and others came with 15a. Regardless of what fuses came with the kit, the maximum recommended fuse for 16awg is 7.5
5 Amps | 10 Amps | 15 Amps | 20 Amps | 25 Amps | 30 Amps | 40 Amps | 50 Amps | 60 Amps | 80 Amps | 100 Amps | |
Wiring Length | |||||||||||
0 - 5 feet | 16-gauge wire | 16-gauge wire | 14-gauge wire | 14-gauge wire | 12-gauge wire | 10-gauge wire | 8-gauge wire | 6-gauge wire | 6-gauge wire | 4-gauge wire | 4-gauge wire |
5-7 feet | 16-gauge wire | 16-gauge wire | 14-gauge wire | 14-gauge wire | 12-gauge wire | 10-gauge wire | 8-gauge wire | 6-gauge wire | 6-gauge wire | 4-gauge wire | 4-gauge wire |
7-10 feet | 16-gauge wire | 14-gauge wire | 12-gauge wire | 12-gauge wire | 10-gauge wire | 10-gauge wire | 8-gauge wire | 6-gauge wire | 6-gauge wire | 4-gauge wire | 4-gauge wire |
If you were to test this then you would probably find that Dashoto is correct, however if it happens in real life then you are unlikely to get a perfect short, and in that case Dashoto's advice is very dangerous.So is Dashoto WRONG about the fuse blowing before causing any damage?
Fit a 5 amp fuse for the camera tap. It is not there to protect the camera, its job is to protect the vehicle, and your life.
With a 15amp fuse on a 16awg wire (rated for 10 amps), the wire is the weak point (i.e., could act as the fuse) and melt before the 15 amp fuse blows. But again, check out the wire gauge and fuse guides.
Yes, the size fuse in the slot for the vehicle should remain (it gets moved to the bottom slot of the fuse tap). The fuse for the camera kit goes in the top slot. They work independently. You do need to make sure however that the fuse tap is placed in the correct +/- orientation.
Use a 5 amp fuse like everyone else.How do you determine the correct +/- Orientation?
- My setup should be correct. Yellow (Bottom Slot) is Vehicle's 20 AMP fuse. Top Slot (Blue) is 15 AMP fuse For Camera.
- Mechanic friend originally installed fuse taps (I had to switch to another fuse because the one used ended up having an issue) right next to the fuse we used.
3. Should I replace the outer fuse for 16 AWG wire with a 5 or 7.5 AMP fuse?
Thanks, but why do you reccomend a fuse that's on when the vehicle's power is on?Find a fuse where a system only functions when vehicle is turned on. I used my heated seats. Avoid any systems that are tied to safety and electronics (Airbags, Infotainment, etc).
S | A129 Dual Wiring | A129 / 129 Duo | 3 | |
G | A129 Duo turns off and on | A129 / 129 Duo | 6 | |
N | A129 Pro Duo front cam broken | A129 / 129 Duo | 0 | |
G | REC light keeps flashing A129 Pro Duo | A129 / 129 Duo | 16 | |
S | A129 Duo Bluetooth interfering with car's TPMS system | A129 / 129 Duo | 2 |
