If the two fuses are connected together at the end of the fuse tap with the cable then yes, but not all fuse taps are built that way.I can't access my fuse box very well but I managed to measure the slot were my fuse tap was plugged in.
I tried this method, I've read a lot about in on german car communities.
Step 1.
Measure on which side of the empty fuse slot are 12 volt. The result was that the voltage is coming from the left side (as painted):
Step 2:
Now it's important to plug the fuse adapter that way that the cable (lead) is on the side with 0 volt:
What do you think of this method, am I safe now?
Pablo Picasso
I will have a look at it tomorrow, those are pictures of my fuse tap but I assume you can't recognize by those pictures.If the two fuses are connected together at the end of the fuse tap with the cable then yes, but not all fuse taps are built that way.
If the fuse tap is built the other way around then no.
The camera fuse has half of the amps compared to the original.If it wont fit the safe way around then make sure that you use a camera fuse that is small compared to the original, eg a 5 amp camera fuse with a 20 amp original, not a 5 amp camera fuse with a 2 amp original.
That sounds easy but I've already destroyed two fuses by pulling them out of the fuse tap, they stuck pretty hard. I'll see if I can do it.To check, plug the fuse tap in with the original fuse removed, your camera should not power on, insert the original fuse and the camera should power on.
Many cars have a plastic tool for removing the fuses, either clipped into the interior fuse box or clipped into the engine compartment fusebox. With the correct tool it should be easy to remove the fuses.That sounds easy but I've already destroyed two fuses by pulling them out of the fuse tap, they stuck pretty hard. I'll see if I can do it.
I know, all of my previous car had this plastic tool, my actual car should have it, but it's not in the place were it should be.
S | A129 Dual Wiring | A129 / 129 Duo | 3 | |
G | A129 Duo turns off and on | A129 / 129 Duo | 6 | |
N | A129 Pro Duo front cam broken | A129 / 129 Duo | 0 | |
G | REC light keeps flashing A129 Pro Duo | A129 / 129 Duo | 16 | |
S | A129 Duo Bluetooth interfering with car's TPMS system | A129 / 129 Duo | 2 |
