Lostinav
So I've been having the same freezing issues that many here have posted about (and it looks like an issue that has gone on for at least 2 years now).
I just got an A129 Plus Duo and was getting the issue, almost always when switching from normal to parking mode. Had to unplug, wait for the unit to shut off, then plug back in to restart the device.
Background:
- Hardwired using Viofo's 3-wire kit and tapped into tested fuses for parking mode power (hazard lights) and normal power (rear wiper)
- Had it set on time lapse recording, later tried auto detect mode
- Rear camera plugged in
- Selected 2K ultrawide mode @ 30fps (1440P 30FPS 21:9 / 1080P 30FPS)
- Low bitrate, WiFi off
- Samsung 128GB high endurance card
- Firmware is latest listed on Viofo's site (v1.5 build 20210515)
- Always set things like time, date, time zone, change speed units, speed off for stamp, etc
Things I tried:
- Different bitrates
- Parking mode from auto detection to time lapse to low bitrate
- Loop recording at 1min, 3min, 5min
- Reformatting card using the device
- Reset camera/device settings
- Power via GPS unit and directly into device
- Default resolution (1440P 30FPS / 1080P 30FPS, not ultradwide)
Findings:
- Almost always freezes/crashes when switching to parking mode or from parking mode with ultrawide resolution, within 2-3 seconds of turning the car off
- Regular 2K resolution works longer, but eventually freezes/crashes (within a day), with auto detection mode, it managed to work overnight, but froze at some point the next day after parking
- Without rear camera plugged in, appears to switch fine even with ultrawide resolution
I am currently doing a test with low bitrate parking mode, and it appears to be working.
Have others been able to find settings or a fix for this that lets them use ultrawide? I guess I can live without but it would be nice to have. Now what I can't live with is the rear camera having to be unplugged for it not to freeze, because that would defeat the purpose of the "duo" model, same for going lower than 1440p for the front cam. I've seen mention of using a PC/computer tool to reformat the microSD card, has that fixed this issue for people? I saw reports from one user where it didn't do anything.
Also saw that Viofo is aware of some problem with the parking mode, any word on if/when it'll be fixed or should we just give up? I just bought this so could potentially return and get a different camera, but I generally like the features of the A129 Plus Duo, if they would work.
Thanks!
Background:
Things I tried:
Findings:
Thanks!
