canibusfan
I just purchased this dashcam. Does it even need a external battery like Cellink NEO? I do plan on using parking mode sometimes
This will depend on where and who the kit is ordered from. We offer just the HK3 kit and the HK3 kit with fuse taps and 5A fuses. Available on Amazon, eBay and our website.It doesn't come with any fuses. You need one for battery or fixed 12 volt supply.
Also, if you use the fuse box, a fuse tap, in my case I needed micro 2, would be a good idea. I thought it came with it, but no.
They also sell fuse tap kit, but only provides 1 of each of 4 types of fuse tap (as per picture). If you have an always on fuse connection, you need a fuse tap. You need two at least and may vary with type you need.
One for constant power and one for accessory power. Best to keep it isolated even if it has it own fuse already. It may be too high, like 20 amp, where 5 amp is adequate.
You may need shrink wrap and solder the items, which will make it water resistant and connectors can loosen or act up intermittent. Especially if on rough roads, dirt road with a truck like mine.
It delayed my installation for park mode... I had to order from amazon and cheaper than there incomplete kit....
I do lots of servicing, so I look for bargain prices and bulk. When it comes to accessories and installation materials, always cheaper to buy from third party. Don't forget shrink wrap and soldering kit if you don't have one.
I find crimping after time seems to act up. Shrink wrapping crimp connectors helps keep out liquids, but soldering is even better, if possible.
I check the local Canadian Tire stores and I refused to buy it, overpriced, since I wasn't in a hurry, nor emergency or essential. So, I ordered online and for same price got more.
